1991 Pontiac 6000 HElp
WOLF663
Engine Mechanical problem
1991 Pontiac 6000 4 cyl Two Wheel Drive Automatic
The vehicle over heated and shut off the motor still turns over but will not start what do you suggest the problem may be
Dec 26, 2009 at 4:07 AM
DOCFIXIT
  • 18,828 POSTS
Warped head and failed headgasket. IE. loss of compression. Compression test will tell.
Dec 30, 2009 at 8:18 AM
