1991 Pontiac 6000 Headlights
1991 PONTIAC 6000
120,000 MILES • 6 CYL • FWD • AUTOMATIC
ORKNEYJOHN
This car's highbeam is not very bright, in fact it seems that low beam is brighter.
These are a Bosch product and are OME. I changed the Bulbs to a higher intensity but this did not seem to help.
My question is there an after market upgrade for this problem and have you had other inquiries related.
Thank you for your response in advance.
John
Nov 8, 2008 at 7:46 PM
  • 110,194 POSTS
John:
If the lights get dim when on high beam, chances are you either have a switch problem or simply a ground problem. Check the wiring to make sure grounds are clean and tight, and make sure you are getting a full 12 volts to the socket when you have the high beams on.
Nov 20, 2008 at 10:37 AM
