1991 Pontiac 6000 Cooling Fan will not operate
1991 PONTIAC 6000
DENO40
Engine Cooling problem
1991 Pontiac 6000 6 cyl Front Wheel Drive Automatic
I changed the cylinoid and the temperature sensor under the thermostat. The fan will not engage at proper temerature or when A/C is swithced to on position. The fan can be jumpered to function with jumper test lead. This began after a Premium Car wash where the under carriage was washed.
Apr 2, 2010 at 3:48 PM
Check and test the fan relay if okay have the computer tested.
Apr 3, 2010 at 12:22 AM
