1991 Pontiac 6000
FIREMOON88
Electrical problem
1991 Pontiac 6000 6 cyl Front Wheel Drive Automatic
i need to know how to replace the voltage regulator in my car. i went to the auto store the other day and had them test the battery, because my 'volts' light was on. they told me it was most likely the voltage regulator. i know it is inside the alternator housing, but i need assistance beyond that point. i also need to find the alternator housing as well.
Nov 18, 2008 at 1:53 AM
  • 110,246 POSTS
Hi:
I recommend replacing the entire alt and not just the regulator. Most likely something caused the regulator to go bad and you may burn up a new one. The alt is on the side of the engine where the belts are located. (passanger side)
If you have any other questions, let me know.
Nov 20, 2008 at 2:34 AM
