1990 Pontiac 6000 idle and acceleration
1990 PONTIAC 6000
44,000 MILES • 6 CYL • FWD • AUTOMATIC
PAGANRICHIE
changed spark plugs but car still continues to idle low and when hit the gas has burst of acceleration
Oct 23, 2010 at 3:40 AM
HMAC300
  • 48,601 POSTS
try cleaning thethrottle plate with choke cleaner and spraying the oblonghole. that 's where the idle air control is. It may be sticking or even bad. If you want to try another idle air control. it should just screw out and when you put the new one in you rhave to drive 40 mph for a little distance for it to reset. But it can also be your throttle position sensor is screwed up as well. Take the choke cleaner and clean that as well, it's a little black looking thing on the oppisite side of where the cables hook up..
Oct 29, 2010 at 10:49 AM
