pontiac 6000 le stationwagon 3.1 motor getting spark will pop with starting fluid how do i determine if it's the computer or the fuel pump in tank
Oct 25, 2009 at 6:01 PM
✓Experienced Mechanic
Check fuel pump pressure. Here is a how to that includes a video showing how to check it. You will need a fuel pressure gauge, but most parts stores will lend or rent them.
