1989 Pontiac 6000 starter removal
ED OGAWA
Engine Mechanical problem
1989 Pontiac 6000 6 cyl Two Wheel Drive Automatic
how is the starter attached
Jan 9, 2009 at 1:53 PM
  • 110,248 POSTS
Hi:
disconnect the battery, remove the wiring from the starter, and there are two bolts that hold the starter to the bellhousing. remove the bolts, remove the starter, and reverse the order to replace.
joe
Feb 27, 2009 at 2:31 PM
