1989 Pontiac 6000 Power Windows
97,000 MILES • 6 CYL • FWD • AUTOMATIC
SCYTHE.2008
The power window on the front passenger side had stopped working a while ago. It wont roll up or down. When this happened the rear passenger window had started acting up. It would only roll up and down from the switch on the door instead of the switch on the driver door as well. Now the rear passenger window will only roll down from the door and will not roll back up. So it is stuck rolled down. The driver switch doesn't work and neither does the switch on the door. I was wondering what would cause this problem since it is only on the passenger side of the car.
Feb 15, 2009 at 3:01 AM
  • 110,248 POSTS
Hi:
Chances are it is the main switch on the driver's door. remove the switch and check for power in and out on the switch. If it has power in but not out, replace the switch.
Feb 27, 2009 at 2:27 PM
