Engine Cooling problem
1989 Pontiac 6000 6 cyl Front Wheel Drive Automatic 145.00 miles
have pontiac 6000le 1989 replaced t-stat and upper hose when running upper hose gets hot so does lower hose but, no hot air. coolant just bubbles into the overflow then temp light comes on. left side of radiator is always cool to the touch. all was good before i changed the t- stat. i had no heat thats why i changed it. help
Nov 1, 2009 at 9:08 AM
