car has a v6 with a distibutorless type ignition,someone removed what would have been the distributor to install a new seal.but since it does not have a distributor i dont see how this could cause the timing to be out as the shaft that is there as far as i understand is only used to drive the oil pump.however after changing all the coil packs new plugs and wires it still runs rough and has a miss.any help would be greatly appreciated.
Jan 29, 2008 at 5:31 AM
