When I start the car the first time there is no problem. After driving 20 miles or so and I shut it down to go into a store and it is off for 15 to 30 minutes it doesn't want to start. If I let it set for a while 15 -20 more minutes it starts right up, usually. Sometimes it will start but sounds as if it is having trouble getting gas, when this happens it usually stalls out,unless I can rev the engine up until it smoothes out. But from a cold start is turns over and starts right up. Fuel pump or fuel filter?
Jul 8, 2010 at 5:35 AM
