1986 Pontiac 6000 shifting into any gear
1986 PONTIAC 6000
300,000 MILES • 6 CYL • 2WD • AUTOMATIC
CARLSHEPP1209
the gear shift lever button has come out of the handle and for awhile i could put the button back in and shift out of park & into gear. now however the button will not push in so i cannot shift gears. what is happening? can it be repaired or can i somehow by pass the need for the button
Dec 11, 2009 at 3:50 PM
HMAC300
  • 48,601 POSTS
I think that is repaired as an assembly . YOu'll probably have to go to a junkyard o find one and replace the whole thing.
Feb 24, 2010 at 10:06 AM
