1984 Pontiac 6000 Not delivering fuel to engine...
134,000 MILES • 4 CYL • FWD • AUTOMATIC
DAVEGREGG
My car still wont deliver fuel. I have given my car a new fuel pump, fuel filter, tune up (plugs, wires, cap, rotor), oil change. The battery is good. I need to know what to try next. The only thing I can think of is the fuel switch. But I don't know where that is located. Any suggestions would be appreciated grately!!!
Thank You
May 24, 2010 at 5:25 AM
  • 75,988 POSTS
If you can hear the fuel pump come on-check the fuel pressure with a gauge and also if the injectors are pulsing. If not check the fuel pump relay/FP fuse
May 24, 2010 at 10:12 PM
