1984 Pontiac 6000 ecm
18,000 MILES • 6 CYL • FWD • AUTOMATIC
MELISSA.JOHNSON43
how do you remove the ecm module from the firewall? is there a bolt/screw? there are clips on the side and i popped them off, but i cant get the harness to remove.
Apr 6, 2010 at 10:24 AM
HMAC300
  • 48,601 POSTS
that's probably not your ECM. Your ECM is probably unde th kick panel on the passenger side.
Apr 6, 2010 at 11:25 AM
