Poly V Belt replacement instructions needed?
250,000 MILES • 1.9L • 4 CYL • 2WD • MANUAL
ALESSANDRO ALBERTIN
  • 12 POSTS
Hi colleagues, I have to change the Poly V belt of this car, can you send me the detailed steps? Thank you very much.
Apr 30, 2023 at 4:34 PM
  • 110,248 POSTS
This vehicle isn't offered in the US, but I will try my best to help.
First, I need to know the specific belt that needs to be replaced. On most vehicles, there is a single serpentine belt, but it sounds like yours is different. Is this a power steering belt, an AC belt, an alternator belt, or something different?
If possible, take a pic of the belt and where it is going so, I can locate adjusters and help you better.
May 1, 2023 at 2:05 PM
BORIS K
  • 836 POSTS
Your vehicle is a direct sister vehicle to the VW Sharan and Seat Alhambra. Fitted with the VAG group 1.9 PD diesel engine.
A good video:
https://youtu.be/hVCJjroPBGg
and
https://youtu.be/ex_ttYE4wAc
The belt layout is on image below.
Hope this helps.
Cheers, Boris
May 1, 2023 at 5:41 PM
