Code P0733 Incorrect gear 3 ratio?
211,000 MILES
LEE H0000
Incorrect gear 3 ratio. Drives fine till 3rd and then shutters and sets the code off. Input shaft sensor replaced but still same. Transmission relearn?
Apr 7, 2025 at 1:21 AM
  • 55,770 POSTS
I would check the fluid condition because if the clutches are burnt up you will have this issue then you will know the problem is internal.
Apr 8, 2025 at 2:15 AM
