ABS Sensor left front wheel
2000 TOYOTA SIENNA
180,000 MILES
RICK ROSS
Speedometer and odometer non op.
Replace cluster now I need to locate sensor VSS/ABS Sensor left front wheel.
Apr 12, 2019 at 1:46 AM
Good afternoon,
The sensor is on the transmission by the outlet of the axles from the transmission.
I attached a picture and description of the code for you.
CIRCUIT DESCRIPTION
The vehicle speed sensor outputs a 4-pulse signal for every revolution of the rotor shaft, which is rotated by the transmission output shaft via the driven gear. After this signal is converted into a more precise rectangular waveform by the waveform shaping circuit inside the combination meter, it is then transmitted to the ECM. The ECM determines the vehicle speed based on the frequency of these pulse signals.
Apr 12, 2019 at 2:41 AM
RICK ROSS
Where is the location of VSS/ABS sensor A or #1 located is it left front? That speed sensor is 2001 up the ABS wheel speed sensor is located on the wheels 2000 an under IRS the cutoff year when transmission changes po500 sensor A or sensor 1. do you know exact location ?
Apr 16, 2019 at 3:49 AM
RICK ROSS
I have been back an fourth with this question. no one seems to know location of sensor 1 there us nothing on transmission. okay I will just take it in frustrated.
Apr 17, 2019 at 11:22 AM
Only other picture I can find.
Hope this helps.
Apr 17, 2019 at 11:33 AM
