Po335 p0336 & p1682
2014 CHEVROLET CRUZE
149,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
ERICSCRUZE
Car stays in reduced power mode with trouble codes p0335 336 & p1682. Runs rough no throttle response & eventually stalls. BUT... if I unplug the crank sensor it starts after slightly extended crank idles smooth no stalling & slight throttle response to around 1800rpms just put new crank sensor, crank sensor connector & negative battery cable & still does the exact same thing! HELP!!!!! I'm going to dig into the underhood fuse box next to try & find any problems for the 1682 ignition switch code.
Jan 4, 2022 at 3:45 PM
