Code po301 misfire
96,000 MILES • 4 CYL • 2WD
JJP1062
  • 17 POSTS
I replaced the coil and plug in cylinder one and still throws same code. What else could it be? No other codes present only po301.
Thanks!
Apr 26, 2022 at 12:53 AM
  • 110,248 POSTS
The misfire, if it is only cylinder 1 can be caused by an injector issue, compression issue, or the new coil/plug isn't being fired.
Do me a favor. Follow the directions in this link and let me know if you are getting spark at the number 1 spark plug:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Let me know what you find.
Apr 26, 2022 at 7:06 AM
JJP1062
  • 17 POSTS
Thank you! Faulty Injector. Solved
Apr 26, 2022 at 7:31 AM
  • 110,248 POSTS
You are very welcome. I'm glad to know you found the issue.
Please feel free to come back anytime in the future. You are always welcome here.
Apr 26, 2022 at 10:59 AM
