Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
Civic
Trouble Codes
P Codes (Powertrain)
P0300 - P0399
P0301
Code po301 misfire
2014 HONDA CIVIC
96,000 MILES • 4 CYL • 2WD
JJP1062
MEMBER
I replaced the coil and plug in cylinder one and still throws same code. What else could it be? No other codes present only po301.
Thanks!
Apr 26, 2022 at 12:53 AM
Experienced Mechanic
The misfire, if it is only cylinder 1 can be caused by an injector issue, compression issue, or the new coil/plug isn't being fired.
Do me a favor. Follow the directions in this link and let me know if you are getting spark at the number 1 spark plug:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Let me know what you find.
Apr 26, 2022 at 7:06 AM
JJP1062
MEMBER
Thank you! Faulty Injector. Solved
Apr 26, 2022 at 7:31 AM
You are very welcome. I'm glad to know you found the issue.
Please feel free to come back anytime in the future. You are always welcome here.
Apr 26, 2022 at 10:59 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
