Po300 code
2004 CHRYSLER SEBRING
159,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
MARKUS88
Car is randomly misfiring, idles rough, but drives okay at normal speeds. Do you know if this car has a known issue with this code p0 300? I have replaced plugs, wires, and air filter. Can the air intake throw this code? Or coils throttle body or crank shaft sensor?
Oct 12, 2018 at 11:41 PM
  • 55,214 POSTS
This can be caused by low fuel pressure or a bad MAP sensor. Here is a guide to help you check the fuel pressure and a diagrams below to show you where the MAP in the diagrams below. Also I would service the throttle bore as well.
and
Cheers, Ken
Oct 15, 2018 at 5:40 AM
