Po171
215,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
NUKEGUMBO
I am getting a lean code on my truck. Changed fuel filter, fuel pump, O2 changed less than year ago. fuel pressure forty two pounds when running. Here is the big question; There is no pressure with the key on engine off, could this cause the lean code/
Dec 7, 2016 at 9:59 PM
HMAC300
  • 48,601 POSTS
lean codes are caused by a bunch of things, vacuum leaks for one. retest fuel pressure see picture for checking. it may have a bad pressure regulator on it. also, check brake booster as they can leak causing the vacuum leak.
Dec 7, 2016 at 10:30 PM
