PO 732
268,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
RHESHA
That is the only code it kicked. I can work on cars, but have never had this issue. If you could help figure out where to start, and what to keep my eyes open for. I have to fix it myself due to serious budget constraints. No 2nd and very little reverse. Will be grateful for any help. Thanks.
Jan 19, 2016 at 11:51 AM
PACO8224
  • 117 POSTS
You can start with the image I sent
Jan 19, 2016 at 12:42 PM
SATURNTECH9
  • 30,869 POSTS
You could have a loose input shaft nut or a line pressure issue in the transmission.You could do a line pressure test which is where I would start.But you would have to buy a transmission pressure test gauge set.About 60-70 for the one I have.You could also remove the transmission valve body and see if the input shaft moves side to side.I would check the transmission pressure First.
Jan 19, 2016 at 12:45 PM
