Where is the PNP sw located?
135 MILES • 5.6L • V8 • 4WD • AUTOMATIC
RAYSIMS
Trying to find the location of the PNP sw. The code "850" will pop up. It will crank but will not start.
It has started a few times, Afterwords the 850 code is there. Where is the sensor located? What does it look like? Can't load a pic, so does it "screw in" (Transfer Neutral Position Switch
Part Number: 32005-7S11A) or "mount on the side"
This is a 4WD, shift is on the column.
Apr 18, 2023 at 8:00 AM
STEVE W.
  • 15,402 POSTS
It is located inside the transmission as part of the control module and valve body. To test it you need to use a scan tool to verify if the switch is changing state from off to on when in park or neutral. Then you use a meter at the ECM on terminal 102 to verify that when the lever is in park or neutral that pin shows zero volts, if it is in other positions, it will show battery voltage. However, your description of an intermittent sounds more like a connection issue, for that I would go under the truck and disconnect the harness at the transmission, inspect it for corrosion or transmission fluid. clean it and reconnect, does it start properly now? If not then do the above testing, the factory service manual basically says, test that wire for operation, use the scan tool and if it's still wrong, replace the valve body in the transmission. Then use the scan tool to program the new module so it will even function.
Apr 19, 2023 at 1:25 PM
RAYSIMS
Steve, I checked the push button switches, all working. I found the wiring had electrical tape. I removed and checked the wiring. I did not find any open insulation but did clean the terminals.
Starts, with no issues so far. I think the wiring was correct. Fingers crossed. Thanks for your help.
May 18, 2023 at 4:49 AM
STEVE W.
  • 15,402 POSTS
Hope it stays fixed. Pin fitment seems to be a problem more now than ever before.
May 18, 2023 at 8:56 AM
