Pneumatic solenoid valve?
30,043 MILES • 1.2L • 2WD • MANUAL
CORSADRIVER
Had the RAC vote out to Mt Vauxhall Corsa d 2010 plate, as I was having trouble with intermittent starting. The mechanic came done a diagnostic test no codes. After tinkering with the car he said its the pneumatic solenoid valve it keeps sticking and needs replacing. Does anyone know what this valve is or is there another name for it. I've searched for part but come up with nothing. Please help
Apr 2, 2023 at 5:57 PM
  • 55,694 POSTS
The pneumatic solenoid valve It may also be referred to as an air bypass valve or idle air control valve. Can I ask if you turn the key on (do not crank the engine over) can you hear the fuel pump come on for about 5 seconds? If not, it sounds like the fuel pump went out. Here is a guide to help us see what's going on:
https://www.2carpros.com/articles/car-not-running-advanced
Please go over this guide and report back.
Apr 3, 2023 at 6:46 AM
CORSADRIVER
Yes you can hear the fuel pump kick in.
Apr 3, 2023 at 6:06 PM
BORIS K
  • 836 POSTS
On Corsa D intermittent non start and no-fault codes can be caused by 2 possible failures.
Fuel pump, as my colleague said, and ignition coil issues.
As you reported back that the fuel pump can be heard running when the vehicle does not start, the next check would be the connector at the ignition coil.
These sometimes can be loose/bad connection and can cause intermittent non start or cutting out.
The coil pack is located in the middle of the valve cover under a plastic cover.
The cover can be removed by sliding it to the transmission side.
The 7-pin connector is located on the left side (transmission side) see images below.
Remove the connector and check that the pins are not burned/corroded.
Sometimes the clip-on top of the connector can be broken, causing a loose-fitting connector.
A good video how to access the coil pack and remove the connector:
https://youtu.be/R9fW29uE9_k
A video showing corrosion under the coil pack and misfire:
https://youtu.be/2i-c_E6AUfs
Once removed, inspect the coil pack for possible corrosion, these often have water entry into the spark plug holes.
Hope this helps.
Cheers, Boris
Apr 3, 2023 at 6:50 PM
