where is the fuse panel
150,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
ARMAAN
I changed the solenoid and clutch and it still behaves the same way. I need to check the fuses where is the panel and what do the fuses do too?
Nov 27, 2019 at 9:51 PM
Here is a guide that will help with testing and replacing fuses:
Below is the info from the manual on these fuses and the locations. Please run through this info and let us know if you have any other questions. Thanks
Jun 14, 2021 at 6:57 AM
