Hi, I replaced fuel pump, fuel fuse relay, rotor distributor, ignition coil. Spark plugs and fuel filter. Car would turn on for two seconds then off. It kept doing this numerous times and a neighbor went to check fuel pressure and pressed on it then engine lit up . I quickly hosed it and no one was hurt. All wires are fine cause only lasted about five second on, but I do not know what to do anymore.
Aug 30, 2018 at 7:28 PM
