1997 Plymouth Voyager Serpentine Belt Fix
JNC7723
  • 7 POSTS
i have a 97 plymouth grand voyager 3.3 engine. problem is it needs two front wheel axles. and the serpitine belt is going to break. what is going to happen if they break
Sep 8, 2006 at 10:29 AM
JPAM
  • 307 POSTS
well dont let it break... if you know its bad why do you want to let it break??
well lose alternater power, ac, water pump, power steering, and anything else that might be run by the belt. and leave you on the side of the road..
replace belt asap..
jess s
Sep 17, 2006 at 2:38 PM
Suggested Repair
Replace the serpentine belt as soon as possible. If it breaks, the alternator, air conditioning, water pump, power steering, and other belt-driven accessories will stop working and can leave the vehicle stranded.
Conversation Summary
The owner of a 1997 Plymouth Grand Voyager with a 3.3 engine said both front wheel axles need replacement and the serpentine belt is about to break, asking what would happen if they fail. The expert advised not waiting for the belt to break and replacing it immediately, because failure would disable the alternator, air conditioning, water pump, power steering, and other belt-driven components and could strand the vehicle.
