1996 Plymouth Voyager Rear Hub Stuck
DRINKSONME29
I have a 96 voyager and the rear passenger wheel bearing went out, im trying to get the hub assembly out but i think its pressed in. do i need a puller to get the hub assembly out? any answers would be greatly appeciated, i been at this for 4 days. ty
Jan 5, 2007 at 5:10 AM
DRINKSONME29
yes exactly like that!
Jan 8, 2007 at 3:42 AM
SERVICE WRITER
  • 9,123 POSTS
I've never seen one like that before :lol:
You may need a puller, Let me see what I can find out.
Jan 8, 2007 at 11:27 AM
DRINKSONME29
cool thanks alot, its got me stumped, i cant get it out for nothing
Jan 8, 2007 at 12:01 PM
SERVICE WRITER
  • 9,123 POSTS
Ok, just did one today, or very similiar anyway. Pull out the 4 bolts from behind and take it out. The book says a half hour.
Well it does!!!!
Use a good slide hammer. first try to pound from behind but it seizes in. Penetrating fluid won't hurt.
Did you say drinks on u?
Jan 9, 2007 at 6:27 AM
Suggested Repair
Remove the four bolts from behind the rear hub. If it is seized, apply penetrating fluid, tap it from behind, and use a slide hammer or puller to remove the hub assembly.
Conversation Summary
The owner of a 1996 Plymouth Voyager could not remove a failed rear passenger wheel hub and asked whether it was pressed in and required a puller. The expert advised removing the four bolts from behind, using penetrating fluid, and using a slide hammer if the hub is seized.
