1991 Plymouth Voyager Intermittent Wipers
GRAINYWAGONS
I own a 1991 Plymouth Voyager SE 120,000miles.
The van has develped a problem which is stummping me. The wipers come on intermittently whenever the car is running. The regulare wiper setting work fine, fast, slowm, interval, but the off is not working.
You can go for a few miles and then they just come on for a few strokes and go back off.
I have gone to the junk yard and replaced the wiper control switch assembly twice.
Could it be the motor, I have a Haynes book but it does not mention a relay.
Thanks for your help.
May 8, 2006 at 8:11 AM
LOSONE
  • 1,616 POSTS
THat vehicle has an intermittant wiper control module that might be the problem
May 8, 2006 at 8:47 AM
GRAINYWAGONS
I have replaced the actual switches for wiper control which includes... the slider for the intermittent wipers. The unit actually contains the on/off switch, (including intermittant, low and high) for the front wipers as well as the wiper/wash for front, the wipers for the rear, and the rear wiper wash. Is this the unit you refer to?
May 8, 2006 at 12:59 PM
LOSONE
  • 1,616 POSTS
No, Chrysler products of thet year had an intermittant wiper module. It is under the dash about a-mid ships. It is black and about the sizes of cigarette pack but a litle longer. Good luck
May 8, 2006 at 1:29 PM
Suggested Repair
Inspect and replace the intermittent wiper control module under the dash near the center. It is a separate black module, slightly longer than a cigarette pack, and is not the wiper switch the owner already replaced.
Conversation Summary
A 1991 Plymouth Voyager with about 120,000 miles has wipers that intermittently sweep a few times while the vehicle is running, even though the switch is off. Low, high, and interval settings work normally. The owner replaced the multifunction wiper switch twice without success. The expert said Chrysler vehicles of that year use a separate intermittent wiper module under the dash near the center and recommended checking that module.
