HELP
INKADDICT
  • PLYMOUTH VOYAGER
I HAVE A 89 PLYMOUTH VOYAGER 4 CYL. 2.5 LTR IT HAS 90,876 ORIGINAL MILES IT STARTS EVERY TIME I TURN THE KEY WITH EASE BUT WILL ONLY RUN FOR A CPL SECONDS THEN SHUTS OFF EVEN IF I ACCELERATE IT SHUTS OFF GOT ANY SUGGESTION I KNOW ITS SOMETHING MOST LIKELY IN THE FUEL SYSTEM LIKE THE MAP SENSOR OR FUEL REGULATOR ARE MY THOUGHTS?
Friday, November 16th, 2007 AT 3:20 PM
BMRFIXIT
  • 19,053 POSTS
Check relays
and fuses
check fuel pressure
check for spark
when turn key on engine off u see engine light
turn the key on off 3 times ending with key on
check engine will flash codes
(code 36will flash like 111 111111)
good luck
Friday, November 16th, 2007 AT 5:52 PM
