front caliper not releasing
HAVOC
93 grand voyager 15inch wheels 112,000 miles front left caliper not releasing when breaks released, overheted rotor. replaced caliper, had same problem, thought rotor may be warped and replaced. still experiencing problem. suspect the distribution block but dont know operation of block. problem only exists onleft front
Apr 20, 2007 at 5:06 AM
PALDOZER
  • 7 POSTS
replace the front left brake hose.although it may look fine upon visual inspection hoses can colapse internally.I always reccomend replacing both sides as they are used equally.also make sure the caliper slides freely back and forth when it is not under any pressure.All slides and rails should be free of rust and applied with a thin coat of anti-sieze
Apr 21, 2007 at 9:18 AM
