I have 1993 Plymouth Grand Voyager LE w/ABS, 3.3 engine and a mileage of about 132K.. Am in process of replacing the left axle assy. Having trouble removing hub assy. have loosing the nut to the bottom ball joint but not removed the joint. Have lossened the two bolts attaching hub to strutt. Won't this change the camber? How do I readjust the camber? also do I need to take the bottom ball joint out of the clamp and do I need to remove the outer tierod end? Thanks.
Jack
Jack
May 17, 2007 at 7:46 AM
