1995 Plymouth Voyager Code 41
ALVEYREEL
Hi all,
I have a 95 Voyager SE 3 speed automatic with overdirve with 300 kms on it.
The "Check Engine" light came on my van. After a few minutes, the battery warning light and the check gages light came on. Since I was using my wipers at that time, I noticed that it was running slow and it would cut off the radio when the wiper was moving. It totally lost power when I arrived home. I was able to restart it after about 30 mins and was able to bring it to the shop. There a check of the ECM showed a code 41.
Appreciate any thoughts on the problem.
Thanks,
Alvey
Nov 16, 2007 at 3:37 PM
MERLIN2021
  • 17,250 POSTS
41=Charging system, alternator, so I would check the alternator...and battery and connections...
Nov 17, 2007 at 12:01 AM
ALVEYREEL
[quote:b5c6663523="merlin2021"]41=Charging system, alternator, so I would check the alternator...and battery and connections...[/quote:b5c6663523]
Merlin,
Thanks a lot. It turned out to be the alternator. Unfortunately, my belt tensioner had some problems too so they needed to replace it.
Thanks again.
Michael
Nov 23, 2007 at 1:32 PM
Suggested Repair
Code 41 indicates a charging-system fault. Check and replace the alternator as needed, and also inspect the battery, connections, and belt tensioner.
Conversation Summary
The owner of a 1995 Plymouth Voyager reported a check-engine light, battery and gauge warnings, slow wipers, radio cutouts, and a loss of power. A shop scan showed code 41. An expert identified it as a charging-system fault and recommended checking the alternator, battery, and connections. The owner later confirmed that the alternator was faulty and the belt tensioner also needed replacement.
