'94 Transmission Slipping
ROBYNHGL
I have a '94 3.0/V6 Voyager.
The transmission will go into low drive and reverse, but will not up-shift into 2nd or 3rd. It goes into gear and the tranny seems strong but once moving the transmission slips and the motor just seems to race.
I replaced the Transmission Pan and filter as well as the fliuds (there was no abnormal metal deposits on the magnet). If I allow the RPM's to go up--it seems to 'want' to kick into 3rd.
What can I look at short of replacing the transmission (which seems to be okay). Where is the Shifter Control Module located? IS this the same as a Transmission Control Module? Or should I be looking at the Speed Sensor?
Thanks for any replies--Robyn
Aug 8, 2007 at 4:12 AM
SERVICE WRITER
  • 9,123 POSTS
Just to add my $.02, when I see this happening it usually turns into a tranny rebuild. There are shift solenoids that go bad or stick. Maybe someone else can chime in, but you may end up throwing good money after bad at this point.
Aug 8, 2007 at 4:56 AM
