1998 Plymouth Voyager Transmission
JORDAN POLING
  • 1998 PLYMOUTH VOYAGER
Transmission problem
1998 Plymouth Voyager Front Wheel Drive Automatic
What all would cause our vans transmission to slip? It runs great, but when we drive it for more than 5 minutes or until the engine is heated up, it slips. It makes a whining sound. What all could be Wrong with it?
Tuesday, February 16th, 2010 AT 6:48 PM
CARADIODOC
  • 34,373 POSTS
Have you checked the fluid level? Which engine do you have? Do you have the three speed or four speed overdrive transmission? The overdrive unit has a big "O" around the letter "D" on the gear indicator in the instrument cluster.
Caradiodoc
Sunday, February 21st, 2010 AT 8:55 AM
