fuel pump relay location
1992 PLYMOUTH VOYAGER
ELIZARDBREATH
We believe that either our fuel pump relay or fuel pump is out. We know how to change the fuel pump but figured we'd try the relay first since it was a cheaper part to buy. I have the new relay part but do not know where to put it. I see two relays on the left side of the car and 4 on the right side. There are also two toward the back under the windshield. Could you please direct me to the specific one that I would need to change. Thank you so much.
Aug 8, 2007 at 7:35 AM
Good idea, Here is the location which is under the hood on the drivers side and a guide to help you test it.
Here is the location (below)
Cheers
Aug 8, 2007 at 10:16 AM
WENDELL MCNEAL
Thank you so much I bough a new relay and the van started, god bless 2carpros. I love you guys
Jun 9, 2008 at 8:26 PM
PATDODDLE
Electrical problem
1993 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
I would like to know the location of the fuel pump or relay on 93 plymouth voyager. I have look on both side of the van under the hood.
Nov 10, 2017 at 11:05 AM (Merged)
Relay Locations -- Under Hood On Left Fender Shield
https://images.2carpros.com/forum/automotive_pictures/12900_fp_33.jpg
CORTOB21
1989 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
Where is e fuel pump relay located on a 1989 grand voyager SE 3.0. I can't find it and I have to jiggle the wiring harness to get the engine to start. Already replaced the fuel pump.
MERLIN2021
  • 17,250 POSTS
Power to the fuel pump is supplied thru the Auto shutdown relay, as shown here, but if wiggling the wires starts the pump, you have a bad wire, not a bad relay!
https://images.2carpros.com/forum/automotive_pictures/62217_ASD_2.jpg
TKDLAD
Electrical problem
1993 Plymouth Voyager Two Wheel Drive Automatic
Where is the fuel pump fuse or relay located on a 1993 Plymouth Voyager?
https://images.2carpros.com/forum/automotive_pictures/12900_fp_29.jpg
