2001 Plymouth Voyager My Interior lights
2001 PLYMOUTH VOYAGER
ARMYWIFE03
Electrical problem
2001 Plymouth Voyager 135,00 miles
Just recently my interor lights flash on and off. Also my door ajar light flashes and makes a the dinging noise. I have only noticed it at night. What do you think the problem is. The rest of the vehicle is fine.
Feb 10, 2008 at 2:30 AM
LEGITIMATE007
  • 5,121 POSTS
check your dimmer switch and you body control module for faults. also the door close switch next to the striker may be loose pull it out and make sure it is connected. it has one screw if im not mistaken.
Feb 14, 2008 at 5:02 AM
