2000 voyager 140,000
2000 PLYMOUTH VOYAGER
CHENESY
how to replace break light switch
Oct 12, 2007 at 10:21 AM
CHEVY22
  • 1,375 POSTS
which one there are two, both are simple , the brake light switch is on the brake pedal , you need two wrenches 14mm if i remember right but dont quote me and the brake on off switch is on the master cyl
jim
Oct 12, 2007 at 10:31 AM
CHENESY
i am not sure but thank you for your help, had a bad experience with goodyear service, they said the switch had to be replaced, thought i could do it my self.
is there a manual online i could look at.
Thanks again
Oct 12, 2007 at 11:23 PM
CHEVY22
  • 1,375 POSTS
yes there is , i would suggest mitchell on demand or mitchell online , one of the two has a diy section , you can purchase a one year subscription for your vehicle for 20 bucks but it only works on the one you sign up for , this is the same material the independent shops use , if you decide to do this let one us know if you need help navigating the site and where to find your info and we will be glad to help, this is very easy and im sure once you get it done it will be a confidence booster
thanks
jim
Oct 13, 2007 at 3:47 AM
