2000 Plymouth Voyager Water Pump
2000 PLYMOUTH VOYAGER
124,000 MILES • 4 CYL • 2WD • AUTOMATIC
PREDECON
I recently went to a mechanic because my van was leaking coolant from the passenger side area of the engine. They told me that I need a new water pump installed and to install a new timing belt and timeing belt kit. 3 years ago (30,000 miles ago)I had a timing belt tensioner and a new timing belt installed but opted not to change the water pump cause there was nothing wrong with it at the time. My question is, since the timing belt is only 3 years 30,000 miles old, does the timing belt really need to be replaced being they last up to 100,000 miles. I would like to only replace the water pump since funds are tight.
Dec 15, 2009 at 1:36 AM
BLUELIGHTNIN6
  • 16,542 POSTS
with only 30k miles on it i would not personally pay for that part of the repair. water pump is all needed here. if the belt was older or had more mileage on it then yes, but not just 3 years / 30k miles.
Jan 25, 2010 at 6:20 PM
