2000 Plymouth Voyager Turns over but no spark
130,000 MILES • 6 CYL • FWD • AUTOMATIC
JMLASANDUS
I was driving to work and all of a sudden the engine stopped running completely. It didn't die down slowly, just stopped running. A friend of mine came to assist and tried to diagnose the problem. We checked the fuses (under the hood and under the dash) and found no burned up fuses. We checked for spark at the plugs and found none. We checked for spark in the distributor and found none. We removed the ignition coil (?) and took it into AZ to be tested. It came back okay. My friend thinks that the timing belt has broken. What else do I need to check before going down that road?
Thanks,
Marion
Jan 11, 2010 at 7:04 AM
JDL
  • 16,098 POSTS
Welcome to the forum, I didn't see a distributor, what is litre size of engine? Check primary voltage at coil and injectors, green wire with orange tracer, engine cranking, If no voltage, I'd check the circuits at the cam and crank sensors.
Jan 11, 2010 at 7:15 AM
