2000 Plymouth Voyager transmissions
2000 PLYMOUTH VOYAGER
LEVARJACKSON
Transmission problem
2000 Plymouth Voyager 6 cyl Wheel Drive Type unknown Automatic 96000 miles
Our Mini van was hooked up to a computer because the "check engine " light came on 2 times, the reading on the computer said "hydraulic pressure switch" the mechanic told us it needs to be replaced and i am having a hard time locating the part on-line or in- stores which direction should i take.--Levar
Dec 19, 2007 at 8:22 AM
BMRFIXIT
  • 19,053 POSTS
[quote:607bbe51ff="levarjackson"]Transmission problem
Our Mini van was hooked up to a computer because the "check engine " light came on 2 times, the reading on the computer said "hydraulic pressure switch" the mechanic told us it needs to be replaced and i am having a hard time locating the part on-line or in- stores which direction should i take.--Levar[/quote:607bbe51ff]
can you get and post the code
p####
if you dont have the code
cycle key on off three times
ending with key on
read the code in the odometer area
most common switch on that tranny is speed sensors
or coil pack
Dec 19, 2007 at 8:34 AM
