2000 Plymouth Voyager oil warning light
2000 PLYMOUTH VOYAGER
150,000 MILES • 6 CYL • FWD • AUTOMATIC
DIETERSCHMIED
  • 8 POSTS
I have an oil light coming on sporadically. It seems to occur more often on a hill or in a turn and it act like the oil is low, but it isn't. So it acts like there is a oil level switch, not unlike a fuel level switch or sensor that is loose.
Does the Chrysler 3.0 engine have an oil level switch? If so, where is it connected?
I don't have an owners manual
Aug 27, 2009 at 3:15 PM
BLUELIGHTNIN6
  • 16,542 POSTS
no, just an oil pressure switch. could be weak oil pump not pumping oil sufficiently, turning and on hills is harder on the pump.
Aug 27, 2009 at 3:26 PM
