2000 Plymouth Voyager hesitant
140,000 MILES • 4 CYL • FWD • AUTOMATIC
STEVENC1986
when i stop at a light or stop sign it idles low almost stalling. also the blower works but no heat comes out, and it leaks collant. filled coolant, still no heat. checked thermostat, works fine.
Dec 6, 2008 at 2:16 AM
  • 110,248 POSTS
Hi:
The idle problem may be a throttle position sensor. The computer should be scanned to check for codes to confirm that. As far as the heat, are both heater core hoses getting hot?
Dec 7, 2008 at 12:12 PM
