2000 Plymouth Voyager alternator
SPRUYTTE
Electrical problem
2000 Plymouth Voyager Front Wheel Drive Automatic
How do I remove the anternator in this van? I can't get the black mounting bracket off to pull the alternator out.
Nov 18, 2008 at 6:20 AM
DAVE H
  • 13,383 POSTS
REMOVAL & INSTALLATION
Removal & Installation (2.4L)
Disconnect negative battery cable. Remove accessory drive belt. Disconnect chassis wiring connector. Remove nut holding B+ cable to back of generator and disconnect B+ cable.
Remove generator mounting bolts. Remove generator. To install, reverse removal procedure. Tighten fasteners to specification. See TORQUE SPECIFICATIONS .
Removal & Installation (3.0L)
Disconnect negative battery cable. Remove windshield wiper housing. Remove accessory drive belt. Remove generator mounting bolts.
Disconnect chassis wiring connector. Remove B+ terminal nut and disconnect B+ cable. Remove wire connectors. Remove generator from vehicle. To install, reverse removal procedure. Tighten fasteners to specification. See TORQUE SPECIFICATIONS .
Removal & Installation (3.3L & 3.8L)
Disconnect negative battery cable. Remove windshield wiper housing. Remove accessory drive belt. Remove generator mounting bolts. Remove generator mount bracket.
Disconnect chassis wiring connector. Remove B+ terminal nut and disconnect B+ cable. Remove generator. To install, reverse removal procedure. Tighten fasteners to specification. See TORQUE SPECIFICATIONS .
Nov 18, 2008 at 8:10 AM
SPRUYTTE
Thankyou for your help, I have everything unhooked for the generator to come out, but I can't get the black mounting bracket off! I took three bolts off that are on the front of the engine, but I can't seem to slide the bracket out. It is inbetween the tensioner pullie bracket and the block. Is there another bolt that I am missing that is on the inside "firewall" side of the engine? I can't find anything and have tried prying at it to get it out.
Nov 18, 2008 at 1:26 PM
DAVE H
  • 13,383 POSTS
what size engine is the vehicle ??? have you removed the windshield wiper housing ???
Nov 18, 2008 at 1:53 PM
SPRUYTTE
That would be my problem. No I have not taken it off. Any chance you can explain in a little more detail how to remove the housing and or provide some pics?
It is a 3.3l
Thanks.
Nov 19, 2008 at 2:00 AM
DAVE H
  • 13,383 POSTS
i'm afraid there is no tech info on how to remove the housing so it must be a fairly simple procedure ..a case of undoing a few screws/nuts i would think the best picture i have got is this .. hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_wiper_2.jpg
Nov 19, 2008 at 3:45 AM
SPRUYTTE
Do I have to remove the wiper arm's? I have heard you need a speacial tool to do that? What is the best way to remove them if needed?
Nov 21, 2008 at 4:20 AM
DAVE H
  • 13,383 POSTS
no you only need to get the cover around top of firewall out of the way ... then the altenator will come out .. like i said earlier it must only screw/bolt on because the books just say .. Remove wiper shield cover ..
Nov 21, 2008 at 4:25 AM
