2000 Plymouth Voyager
PMAC1789
HOW DO I TAKE OFF THE FRONT DRIVER SIDE HUB BEARING.
Jul 12, 2008 at 9:39 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:db537ecda8="pmac1789"]2000 Plymouth Voyager
HOW DO I TAKE OFF THE FRONT DRIVER SIDE HUB BEARING.[/quote:db537ecda8]
The hub assembly is bolted on. After removing the brake rotor look on the back side and you should see 4 bolts. You will also need to remove the spindle nut from the drive axle.....
Jul 12, 2008 at 2:26 PM
