1999 Plymouth Voyager Water from A/c leaking into Car
1999 PLYMOUTH VOYAGER
156,000 MILES • 6 CYL • 2WD • AUTOMATIC
JFAZEK
Water (not-antifreeze) has just started leaking INSIDE car when a/c has been on - I can hear it "sloshing around" near heater core. How does this water normally exit vehicle? Thanks for your help!
JFazek
Jun 9, 2009 at 1:04 PM
JALOPYPAPA
  • 467 POSTS
No doubt you've seen water dripping from an air conditioner as moisture in the air blown over the cooling part, the evaporator, condenses on it. The same thing happens in cars, with the same solution: a tray to collect the water and a drain tube to direct it away, in this case under the car onto the pavement. In your case, this drain tube is clogged with debris. You should be able to see it just behind the engine to the passenger side of center and push a soft wire up through it to get it unclogged.
Jun 10, 2009 at 1:55 AM
JFAZEK
Thanks for the tip, but it didn't work. It turns out the water leak was coming through the a/c unit from under the hood of the car - it was rainwater! On the Voyager there is a hose which drains this water to the ground; it was clogged with debris. Tricky!
Jun 16, 2009 at 10:21 AM
