1999 Plymouth Voyager vehicle jerks when driving
75,000 MILES • 6 CYL • FWD • AUTOMATIC
TIANNA305
I bought a bad deal. I have had the erg, crank sensor, cam sensor, alternator, transmission, belt, radiator replaced.
Feb 7, 2010 at 11:47 AM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Cap and rotor
Note:If it doesn't apply disregard.
Feb 7, 2010 at 9:48 PM
