1999 Plymouth Voyager transmission wont shift out of first
1999 PLYMOUTH VOYAGER
115,000 MILES • 6 CYL • FWD • AUTOMATIC
ALSTIDHAM
My transmission wont shift out of first gear. I ran it on my computer and its coming up with Transmission Control System Malfunction. Would it be the TCM or the PCM?
Dec 31, 2007 at 10:45 AM
BMRFIXIT
  • 19,053 POSTS
[quote:445537e80a="AlStidham"]Transmission problem
1999 Plymouth Voyager 6 cyl Front Wheel Drive Automatic 115000 miles
My transmission wont shift out of first gear. I ran it on my computer and its coming up with Transmission Control System Malfunction. Would it be the TCM or the PCM?[/quote:445537e80a]
try to run a check on the solenoid pack mounted on the side of the tranny
if OK check wiring then TCM
1st I would do the solenoid pack
8 of 10 it is solenoid pack
Jan 5, 2008 at 10:53 PM
