1999 Plymouth Voyager STARTER
134,657 MILES • 6 CYL • FWD • AUTOMATIC
BIGTEATS
NO POWER TO SMALL WIRE AT STARTER , CHECKED RELAY , NO POWER FROM RELAY, JUMP RELAY AND VAN CRANKS
Apr 2, 2009 at 5:43 AM
2CARPRO JACK
  • 11,533 POSTS
Check the red wire out of the ignition switch for power in the crank position.I have included the wiring diagram to help in figuring this out
https://images.2carpros.com/forum/automotive_pictures/1639_plymouth_1.jpg
Apr 2, 2009 at 5:48 AM
JDL
  • 16,098 POSTS
Did you check for voltage at the relay circuits? With the key in the crank position, there should be two hot terminals. Terminal 30 is hot all the time, terminal 86 goes hot with the key in the crank position. Use a testlite.
Apr 2, 2009 at 5:55 AM
BIGTEATS
NO POWER AT 86 , HAVE POWER AT IGNITION SWITCH
Apr 2, 2009 at 6:02 AM
JDL
  • 16,098 POSTS
Hi, Jack gave you a wiring diagram. Sometimes the 85 and 86 terminals are switched on the wiring diagrams, did you check both for voltage? If no voltage, check the fuse circuit in the diagram.
In the past, I have started Chrysler type vehicles, by jumping the starter relay, like you did. I make sure the tranny is in park or neutral, e-brake set, turn on the key, jump the relay. It won't fix the problem,but, may get the vehicle running. Remove the jumper if the vehicle starts.
Apr 2, 2009 at 6:51 AM
